I'm all wet
belsie
Caught in Florida downpour and found I have some top T-Top leaks (imagine that). What thru me was my drivers sunvisor is off and water dripped hard thru the mount hole right on my leg. Curious as to 2 things:
1. top seals look good / soft with no rust visible on top or pillar area, where could water be coming from?
2. if visor was in place where would that water have gone? Does the pillar area collect and could drains be created at pillar bottom?
Any help or advice appreciated!!!
Pull your windshield trim off and look for rust if you havent already. Also Try sitting in the car while someone sprays with a garden hose and have a look. Mine seems to be okay now, but I even had water coming in from a small hole in the firewall that I discovered.
With the visor in place best bet is that water heads down the A pilar toward the ECM area.
