SignUp Now!Thanks nat, there's nothing else to check the battery and alt are new and all wires are fine and grounds are secureCheck the bulb
It comes on when I turn the key to prime and she starts right up thanks for the info broIf your volt light does not come on when you turn the key to on, your alternator will not charge your system. You must unfasten you speedo case and reposition or jiggle it until the light comes on, and then refasten it. I don't know if that's your low idle problem, but I do know if no volt light, no charge.
now that's a diagramThis should help you. 3rd paragraph and forward.
http://www.installationinstructions.com/FYI/alternator_charging_tech.pdf
In post 19 you said it doesn't turn on. What fixed it?
I think my car is haunted , but I called my mechanic to get her inspected and I told him what was up and he told me basically what you guys said,In post 19 you said it doesn't turn on. What fixed it?
