in line check valve
pajo
I just converted to a vacoom brakes and was just wondering is there a inline check valve I can put in before I blow up the diafram on the new booster i just put in..
check valve
Hi Zeus
I do understand that the check valve goes in between the motor and vacoom line to the booster but I wanted to know what brand and part #check valve.Thanks anyhow.
Sorry man, I just couldn't help myself. :biggrin:
I don't get a good change to be a sa very often. :tongue:
Your question has been asked multiple times. If you search this section enough you can find the answer. I would go for 'check valve' and see what turns up. I believe you need one for the TTA.
HTH, and good luck with your conversion.
On my already converted GN, the vacuum fitting on the booster itself is a check valve. If yours isn't, autozone sells the same exact looking part that is, however I haven't tried to see if it fits or not as mine seems to still work fine. Its in the help section, the red generic parts. HTH
check valve
thank you all - question answered and jedi knight may the force be with you ...:)
