Individual cyl.fueling
N2BUICK
TurboBuick.Com Supporter!
How is this option utilized?
Would you need to get t-couple readings from all cylinders,to put this to use?
Currently have felpro seq.with wb o2 system. I have a chance to
"trade" into the same system,except with the individual cylinder fueling option.Looking for reasons to make the change?
Combination is Buick V-6,single big ,turbo (88), motor,and injectors.
TIA
Austin
Individual cyl tuning
In the FWIW dept,I would think the most accurate method is the ind. EGT readings, unless you are an expert at reading the plugs.;)
I have discussed this very subject w/ Steve @ SMC and he has developed a 8 channel EGT system that should be available soon.
I have some other limited exposure to the tuning concerning a blown moostwang. The $5000 I/C/intake made by a "famous" manifold guru, put the T/B on the side of the engine, thus the hi volume of incoming air at 27PSI, leaned all the opposite bank cylinders to a point of repeated failure.:mad:
The fix was to add the ind. tuning to the FP and add 10% fuel to the dr side cylinders.
HTH,:cool:
