Hotfoot
- Jan 1, 2016
that is really sexy!!!
SignUp Now!that is really sexy!!!
what controller would you run? with the throttles down by the ports like that you will have no manifold vacuum to speak of for running speed density at part throttle.
So you could run with a MAF, or use a blended Alpha-N / Speed-Density system of some flavor or other.
Would be a fun project though.
Bob
I've set up a couple IR intakes w/ efi. We use a vac block plumbed to each runner, then to a MAP sensor.
John Kaase welds a plenum under the intake w/ holes in each runner, and taps the plenum for MAP.
As Neal stated, syncing all runners is a biatch.
The other item is the response is TOUCHY!! Compare the area of all the ports, vs 1 t/b. Open the blades just a "RCH", and it's "game on"!
Wow that looks like a home made / soldered circuit board. NeatI would need a EGT on each cylinder to dial them in . I also have a Ecm from a Indy car . I will be going back to get another nice one from him . He gave me this beat up one just to play around with . He has All shorts sensors, EGTs ,linear movement sensor Ect
Once you have used an EGT probe on every cylinder to monitor and tune an expensive engine........................I would need a EGT on each cylinder to dial them in . I also have a Ecm from a Indy car . I will be going back to get another nice one from him . He gave me this beat up one just to play around with . He has All shorts sensors, EGTs ,linear movement sensor Ect
It definitely has the cool factor going for it. It looks like you could completely remove the IR throttle linkage and bolt the runners back to the base and put a conventional TB on it with minimal work and still be able to use stock ecm.Check it out and yes it is a later intake . I also got a cam blank and a Ecm but the intake is going to need some spacers to make it work but besides that I think it will not be that bad to adapt to my set up . I still need some stage heads but I can find those everywhere View attachment 295321View attachment 295322View attachment 295323
