This is a little confusing. I am almost sure that the front offset on a GTA wheel is 0 and the rear is 16mm....With that being said, why not just use the fronts on the front of a GN and use the rears on the rear of a GN with a 5/8 spacer and longer studs? If 16mm equals .630", then 5/8 spacer (.625) should bring it back to 0 offset. Then you wouldnt have to go trying to buy all fronts which can be difficult unless you go with the new ones. Am i missing something here? Seems like a simple concept.
