I have sort of a build thread going here.. http://turbobuick.com/forums/threads/pulling-60k-mile-engine-for-the-first-time.389246/
SignUp Now!Anybody running the 295-16 drag radial yet ?
1-Damaged or worn front end parts, repair and replace such item's then your fronts should work.I've got rears on rear using adapter from Kirbans. Works perfect. Used the hub centric adapters from their site.
Fronts have an issue. They hit the lower ball joint. Tried a 1/4" spacer....not enough. Need another 1/4" anyway....a total of 1/2 inch would do it. This way u have the wider lip in the rear for that gnx look.
Working on my solution for fronts in front!
Why don't my fronts fit? Stock GN spindle and suspension.....stock dimpled GTA wheels.....
Run down to autozone, they carry a full black set with locks.
Are those orig gnx wheels?
Fit no problem. No issuesIs anybody running GTA fronts with a 275/45/16 and does it clear the frame and wheel well okay?
Good luck. Jegs don't have them rims. they say they do, but there drop freight from oer an Oer ain't making them right now. As for fit.4fronts work great.I came across these GTA rims for sale from Jegs. I am interested in buying them, but I cannot get a straight answer as to whether or not they appear like a stock front GTA rim. The picture doesn't show the width of the lip near the black mesh center and the representative that I spoke to at Jegs was less than helpful. He told me that the only picture he had was the one on the site. Anybody have these (0 offset) on their GN/Turbo T currently? I have sent a request for a different picture of the rim to OER, but have not gotten a response from them.
http://www.jegs.com/i/OER/691/R4410/10002/-1?parentProductId=1936277
