Burned a chip for 50's to break in a new motor. The first 100 miles were very easy and did not use DS. Have 200+ miles and decided to hook up DS and dial it in a bit. Got around 7 degrees of knock at 18# of boost but have some fine tuning to do. However I looked at my injector duty cycle and it was 130%!!!. My base fuel pressure is 40-41# and 02's look good 780-800mV. In scope mode the curves are crossing which is not good. How do I prevent the injectors from going to 130%? I have the ability to do chips but I'm fairly new to 50's. I know I'm not overrunning the injectors as my combo is a 62, stock heads with valve job, 50's, 2800-3000 stall and stock bottom end. My inj. constant is 45 which is my first problem but I just found that out. TIA..
M. Banas
87GN
M. Banas
87GN
