Is it advisable to hotwire the injector harness when using standard high impedance injectors or would it be a waste of time? My understanding is that it would be beneficial when using low impedance injectors but with standard injectors, the jury is still out.
Second question: Instead of buying a whole separate hotwire harness, could I just splice into my CCCI hotwire kit and add an additional feed wire so that the two systems (ignition and injectors) share a hotwired 12v source or would this overload the wiring/relay?
