Injector ID Please
getchasum
MISSING 2 CYLINDERS???
Does anyone know whos injectors Postons sale. I bought a set of they're 36lbs, a year back. They look a lot like the stock ones but they do have a little gray on them. If it helps, they are stamped RP on them.
Thanks,
There will be a part number on them too. If you can get that, it should be easy to research and identify em'. I do know that the newer 36# injectors (not the Ford Blue Tops), have a different appearance than the Blue Tops that most people are accustomed to using.
Please post the part number, and some of us can hopefully help verify it for you. Also, gnttype.org has some good listings for different injector numbers and ratings.
