injector o rings leaking?
redd222
my engine is running rich blm r kinda low stock injectors chip fpr
when i spray starting fluid on/at the injectors blm drops even lower.
wondering if bad o rings could b the problem for my engine running rich.
alsor your blms supposed to drop when u step on the gas.
Does that mean the car has the stock chip still in it? stock regulator, maf etc. etc.?
I would definitely look at the fuel injector o rings if you say they are leaking, maybe pull the rail off and try and reseat the injectors or replace the o rings if bad or ripped.
If you think the o rings are leaking heres a trick with the engine running use some crc penetrating oil spay it where the inj. goes into the intake and see if it sucks it in if it stays around the base the o ring is ok also you would hear a vaccume leak ( ask me how i know)
