delcowizzid
newzealand turbo 3.8
- Mar 3, 2010
hey guys im currently setting up for meth injection useing 2 spare ecu outputs to trigger the pump and 1 or 2 injectors that are PWM controlled via the ecu .will be triggering and varying injector duty via a MAP V's RPM lookup table and may use an intake temp table as well but that will be later if i do.now what sort of flow of meth am i going to need to effectively cool an allready intercooled intake charge.its standard 3800 later 89 model NA engine with turbo added as in my ride thread on here.im trying to work out what flow in LB/hr injectors i need for a single or duel injector setup . cheers guys
