Injector size??
MN250R
Need help on what injectors to go with my mods,
Thrasher chip, looking to get a turbo tweak one. Ram air kit, 160 thrmostat.
Walbro fuel pump, adj regualtor
THDP, 2 3/4 exhaust, pats 2800 l/u converter. built trans. Maybe a few other small mods i may be missing.
Future mods would be a plenum spacer, ta49 turbo, maybe a slightly larger intercooler.
What size injector would you reccomened?
Are tomco 32# disk type ok? or go larger?
get the 65lb'ers from full throttle speed right off the bat, they work very well, and basically they are all the same price, so why not get the big ones. also when you say plenum spacer do you mean a power plate or just a spacer. I ask because the spacers do absolutely nothing and are a waste. also if you want to go faster than 11's ever get something bigger than a TA-49, you have a good trans and good converter, look into the 3255 or 6152 turbos from full throttle as well.
Thanks for the help!
Ya i mean the power plate that evens the air flow out , something like that. Not the spacer. I cant wait to get my car back, its at the tranny shop now.
I will look into those injectors and the turbos
Should be a big difference with the stall and tranny.
would 42.5 injectors be to small? how much will they support?
would they be able to handle the 6152 turbo? along with the pther mods i have includung a power plate?
any injector will handle it, to a point. you gotta ask yourself "how fast do i want to go?" the 42.5s i wouldnt take much over 400whp, i would spend the extra now for the 60s, theyre good to about as far as you want to take a stock crank/rods combo.
Gary
If you are gonna buy new injectors... do yourself a favor and get the Motron 60's.... some people refer to them as 65's.... they work great (when matched with an Eric Marshall chip)... even on a stock car..... and when the upgrades do happen.... they have enough room to go 10's through the quarter... without sweating it...
just buy once.... it will save $$ in the future...
Thanks, thats what im gonna do after being on the turbotweak website and seeing them.
