Hi I see you are considering 80 lb injectors. I am switching over to e85. Before i decided to do this I had my stock turbo. It went bad so i bought a used turbo that eventually turned out to be bad. The used turbo was slightly bigger so I ordered the 80lb injectors for it. We’ll upon start up the turbo began to smoke bad (bad seals). So, we shut it down to figure things out. Long story short ended up buying a bigger turbo 6262, a new torque converter (2800 stall non lock up), new fuel pump and lines for e85, and 120 lb injectors. The injectors are flow matched and I also have the matching 5.7 chip as well. I’m asking $300 shipping included.
