Chuck, you just reminded me why old geezer's get paid more money - experience!
You are so correct that the pump orientation really doesn't matter... oh well, the advise resulted in my pump inlet fitting being lower with respect to the tank outlet (actually .5" lower) whereas the original mounting configuration I had it in (but never ran) was about 3" higher than the outlet so I'm better off anyway.
I'm running the Weldon 40 micron inlet filter and a weldon 10 micron outlet filter.
After speaking with Earl at Kinsler, I believe my problem might be a stuck fuel pressure regulator (FPR). I removed the pump motor and the lovejoy coupling is in tact and the pump turns freely. The motor sounded fine as well.
Plugging the return line is the only test I didn't do at the track the other day - I now wish I had as I remember what I did just before the car nosed over.
I was nearing 8000rpm in 1st gear and I started drifting out of the groove (25mph cross wind that day). The car started to fish tail and the wall was pretty close so I got out of the gas, steered the car back into the groove and instead of coasting down the rest of the track, I punched it down and then shifted second. The car nosed over right after I shifted into second gear.
When I think about the vacuum/pressure that the FPR "saw" during that episode in my car (30psi boost to -12" vacuum back to 30 psi boost) - a stuck FPR does seem very plausible...
The return line I have from the FPR is a -6AN. With the regulator stuck wide open (where it should have been when I let off the gas - at high vacuum) the return line might present just enough restriction to build enough pressure to start and idle but not enough to handle the AE fuel shot my blower requires. The new weldon pump does make more fuel pressure than the dual SX setup I previously had and the blower makes more boost so the FPR will have to adjust further in both directions - some buildup/deposits may have just hung it up in the full open state.
I'll put the thing back together one more time, fuel it up, and see what it does with the return line plugged. I might just have to disassemble the FPR and clean it out for a fix.
Alex
(feeling embarrassed right now but perhaps a little smarter)
![Big Grin :D :D](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f600.png)
