I have a V2 Cas FM,TE61 turbo.Has anyone ever measure the  temperature entering the intake manifold under boost conditions and what temperature is the outside air when readings are taken?I need to know how hot the incoming air is to calculate the turbo efficiency and HP range and supporting fuel requirements using the compressor map of the turbo.
Thanks in advance
			Thanks in advance
