The one on top of the water crossover by the thermostat - that's the fan on switch right? Does the computer use that or is it an override? (gray plastic part is round and has only one terminal in the middle)
The water temperature sensor that reads for the computer, that's the one that has a little screw on knob to capture the wire eyelet. Correct?
How about the one that has the weatherpack connector and two wire leads in side it. Kinda oval shaped.
Any others?
>>> What does the car require for proper computer operation and fan operation?
I really only have room for three. I'm going to use a FAST and will probably use a switch from the round gray one to control relays for both electric fans. That only leaves one for the computer to read and then one for a tempterature gauge. I'll give up fan control on the FAST as I can get a 176 (on temperature) / 160 (off temperature) from JET.
Thanks,
Roger
Any others?
Thanks,
Roger
