- May 28, 2001
Boost and timing, how low to go?
Does, or should, the reduction in timing based on boost ever get to the point where I need to stop reducing the timing? For example, I'm at 15 degrees at 29psi (plugs look good) and 20 degrees at 19 psi. Does that ratio of 1 degree for every 2 psi carry on at 39 psi and 44 psi? Or is there a...
