The reason turbo Buicks do not have cooling system issues like that is most of us use RMI-25 in our cooling systems, and also are smart enough to know the cooling system need periodic servicing!
When running a fleet of commercial trucks in the desert summer heat during the 1980's, my biggest service issue was the cooling system.
I tried every additive and snake oil available to remedy this situation and finally came across RMI-25 which has become my "magic elixir" which contains all the necessary elements to protect the cooling system, and actually keep it cooler since is also contains a surficant to break down surface tension for better heat transfer.
To this day, no other cooling system additive can equal the protection and performance of RMI-25.
Not only does it contain all the necessary elements for protection, it also cleans the system while you drive and does NOT use any harsh detergents or acidic ingredient which will help erode the cooling system.
As far as using distilled water, that is fine, but not necessary. My original T proves this with 9500 miles and RMI, and the radiator is as clean as new and never used distilled water.
Like most things in this life, additives and antifreeze do not last forever. Our recommendation is to service the cooling system by flushing every Fall and add RMI and antifreeze, in the Spring dump the A/F and add RMI with water of your choice.
We do not use antifreeze here in the desert, so we add a dose of RMI at least every year with low mileage cars, and dump it very couple years .
Not to bash our competition, but WaterWetter, Royal Purple and others do NOT have all the needed elements, nor will they clean the cooling system.
For example, I used WaterWetter before RMI, and found the cooling system would go corrosive as it will then remove solder from joints after a year or so?
For $10 a year and a little time, it is very easy and simple to protect your cooling system.
Like many others, I add RMI to my late model cars, and I know one local owner that has used it regularly in his truck since new in 2003, and never drained or flushed the cooling system yet, and does not need to yet!
I know there are hundreds, actually thousands, of turbo Buick owners that use RMI and do not see issues like posted above from the other forum - using RMI properly will solve his issue!
