Interior Parts, Torque Converters, Front timing covers, BQ trans...TRADES
jdpolzin
Tan 60/40 non pillow top bench with rear seat:
Rear is very nice, passenger front is nice, drivers has only minor wear (had a cover on it) 8 out of 10
$250 set
Tan/Saddle Dash:
Nice shape, no cracks, no fading, only one minor indention on the top from something sitting on it, will likely come back out
$100
Maroon Buckets and Console:
These were made from a 60/40. Material is in nice condition. Console looks good in our cars, nice upgrade for a column shift car
$250
Timing Covers: GM
20 bolt and 14 bolt. Both is good shape $50 each
Torque Converters:
CVC stock replacement 6K miles lock up $100 shipped
Grilles:
84 GN Grille: In good shape but chrome is starting to bubble at the top $50
87 GN grille in great shape, freshly painted $250
Steering Columns:
Tan/Saddle column shift, nice condition, $100
Dark Slate Grey, column shift out of 84 T, $100
BQ 2004r Transmission. Previously rebuilt, shifted fine, unknown mileage on rebuild but 70k on the car $600
TURBO Flexplate $50
Vacuum Brake Conversion $175
I'm looking for a few odds and ins for an 86-87 engine.
1 L shape bracket that attaches to the bottom header bolt and the AC compressor,
2. Rounded Y bracket that attaches to the top header bot and the back of the alternator
3. TV/Throttle Cable bracket
4. Hard Vacuum Line Set
5. Tensioner Pulley
6. Hard Coolant Lines
7. Two Throttle Bodies
8. 3" THDP
9. 80# injectors
10. Thermostat housing and clamp
11. 10" 3000 stall converter lock up
12. 7.5 Posi Rear End with 3 series gear
13. Hotwire Kit
14. 3" MAF Pipe (doesn't have to be pretty)
Would you ship the dashboard ?
Yeah man! I could do that. I also have tan upper and lower door panels, tan trim, tan seat belts, third brake light, visors, etc. If you were to want a bulk of the parts, it's probably best to ship on a pallet through Fastenal.
10-4. Get me a quote. I am interested
Jer..
U need 1 of these?
I also have the hard vac. Lines but currently boxed up for a move ..
