ttypewhite
- Oct 1, 2001
I ran 9.94@134mph with that cam in my old 109 combo. Stock stroke, gn1 alum, 70gtq turbo at 24 psi.
SignUp Now!Thanks. The other supporting HW is the reason I will have to wait until 2015 to get started. Engine, transmission and rear end. Couple year project and last time I will be able to spent the kind of money it takes to do this. I f'up and that's that. So I'm going to do it right.Running 218/212 roller cam, stroked w/6265. Mid to bottom 10s should be a cake walk... Like mentioned, all other supporting hardware should be there. GL on your que$t!
I'm hoping it will work with ported irons. Thanks for the info.I ran 9.94@134mph with that cam in my old 109 combo. Stock stroke, gn1 alum, 70gtq turbo at 24 psi.
What's the lift, duration, lobe separation, etc?? One set of numbers doesn't tell the whole story.
I helped with a 9.70 iron headed car that runs way less camshaft than that..
I have already replaced my stock cam with a flat tappet 206/206. The problem is, the motor that is currently in my car, I wiped a couple of cam lobes and I just replaced the cam. So it is in my best interest to rebuild, just it case the main bearing go. I have already purchased a block, it has been magna-fluxed, billet center main caps, ARP main studs and a used 224/218 cam with nose hardware, lifters, push rods for iron heads, timing chain and gear. Regardless of what size cam, I putting a billet roller in my rebuild.stock cam is fine for 10.50s and ported irons. I can run mid 10s no problem at 25lbs of boost with my GN.
My car weighs 4050lbs with me in it. I have a 224/224 this in a 4.1. On pump gas 18' of timing and 19psi I went 11.5@116mph, converter unlocked, car was bucking bad at the end of the 1/4 and my lifters were giving me problems. I wasn't on slicks, so anything over 2psi of boost off the line would fry the tires. The run in my signature was with 17psi.
Well Jason I am definitely going with a smaller camshaft. I'm one of the people who like a smoother idle, if possible. I just posted that I will be going with a smaller camshaft, primarily because the car will be street driven 75% of the time. I will be taking it to the strip, no doubt, but that will be on days when the various clubs have private rentals and on the no E.Ts nights otherwise I will get thrown off.I think you'll be happier with a smaller camshaft in the 206/210 range. Better idle and driveability etc.. And anything stock or over stock will be plenty for mid 10s. A 206 roller seems to work well with irons and will go deep tens easy with the right combo.
Once my engine is rebuilt, I will be upgrading turbo, converter, fuel pump, injectors and rebuilding my trans.probably want to upgrade the turbo too. That is probably holding you back the most right now.
Also I have a stock trans and a restalled D5 converter. If I got a bigger turbo, then I would need a new converter. I don't want to have to buy things twice, already have to do that because I didn't post this question before I bought a used cam. Also, I don't want to push the stock transmission too far.probably want to upgrade the turbo too. That is probably holding you back the most right now.
It is a kick ass video. Apparently the music offended a board member because its "satanic lyrics that mocks jesus". As if it is fact that satan and jesus exist/existed. Jason, being the nice guy that he is, apologized and said that the music didn't represent his beliefs. I posted that I saw no reason for an apology and no reason for Jason to defend his beliefs. Simply because it ain't nobody Else's damn business what he believes.Jason, Thanks for that video That is the closest I will be to an 8 second run.... I have to admit I watched it a bunch of times, just a Kick Ass Video...
Anyway, I don't want to get off topic here.
