Is Boost Creep bad or Good???
BADDGUY6
Senior Member
Is Boost creep bad or good "IF" you get no KR? Ran the car last night. And had boost creep. Went from 21# to 25# in 3rd with 1-2* KR, 02s 810, w/Alky pump speed 5
Boost creep is "bad" because if you can run 25 psi in 3rd, you can definately run 25 psi in first and second and you will be faster, overall. If you tried to run 25 psi in 1st and 2nd, but have boost creep, you would likely get knock in 3rd.
It's bad. If your car 'creeps' up a few psi and doesn't knock, then you could have been running that psi the whole time in every gear, not just 3rd gear where the creep happened.
What if your car couldn't take any more than you had it set for, and it creeped, and you didn't get off it? Yes boys and girls, that would be bad.
