- Aug 6, 2001
I’m at a crossroads. I just picked up a wideband O2 and a Powerlogger. I have stock heads and turbo but am about to drop in the Racetronix 255LPH pump with hanger and have been running 60lb injectors.
E85 is readily available in my area so I don’t plan on doing alky. Long term I plan on doing a major fuel upgrade with new lines, hanger, pump upgrade and filter as well as bigger injectors and probably the ecuGN.
In the meantime, with my above setup and stock lines does it make sense to have my new chip for the WB burned for E85?
I realize that with 60lb injectors I won’t be able to get a crazy amount of flow (30% more fuel needed for E85) and I am concerned about using stock lines.
Suggestions?
Suggestions?
