to run 104 unleaded with eric's alky chip without alky. I haven't bought the alky kit yet and was wondering if race fuel would work with out changing chip settings. I will run 21 psi if it will be o.k.
The timing will be ok but the fuel won't be right. You should start with the boost lower, maybe 18psi. You'll have to experiment with the WOT fuel and creep the boost up, adding fuel as you go.
