is my engine gone? video
What's the oil pressure reading? Put a hose to your ear and try to locate the general area...valve cover, under intake? Looks like an ATR inter cooler and M&A heads?
The oil pressure is good about how it's been around 15-20psi when all warmed and idling and goes up with rpm
Listening to video is much different than in person.Have you checked the headers for cracks?
That sounds much worse than clicky lifters......When mine sounded like that it was a rod bearing that spun.
Bryan
I live in rapid city SD. And there's no one near me so if it is the engine I'm going to have to pull it and send it off
Kinda sounds like a dry rocker. Maybe a push rod got plugged or valves need adjusted if adjustable.
Pull the valve covers and inspect the rockers and push rods. Tell us what you find.
Pull the valve covers and inspect valvetrain first. Sounds like a broken rocker shaft or something in that area. Sounds like it's coming from the Passenger side.
i listen to it this morning and i know its either the passenger side or intake its coming from. i pulled both valve covers and checked and not sure what i was looking for but the passenger side did have two lifters with no play seemed might be locked up?
Hey brotha, start the car with the valve cover off and tell us or show us what you see.
Does this mean it's done just cut the oil filter
Damn!!!! Time to go buy a cherry picker.
What does the oil pan look like?
havent pulled it yet. any good engine builders no one around here so i know im going to have to send it off.
