Car slows down fine, but when I get to a complete stop the pedal creeps to the floor and I can feel a vibration in it. Brakes worked OK before I changed to bigger wheel cylinders. I have bleed them out at least 5 times and can,t find any leaks WTF?
The bigger wheel cylinder should not have anything to do with it.
As much as I hate to say it, yes. The seals in your main cylinder are going. The pedal creeping to the floor is a classic sign that most standard brake systems experience. It may be coincidence, but probably caused from pump bleeding when you finished your cylinder installation. Guessing The P/M is original to the car?
The vibration you feel is the P/M pump keeping the pressure up as it leaks past the seals.
Stop driving the vehicle before you can't stop any more and repair the problem.
You might try cycling your accumulator. It may have some air in it.
The bump you feel is the pump building presure.
Could also be the pump trying to run against an old hardening acc ball.
Get a watch, clock, or some good time piece and run some diagnostics. Brake System
Find out what time it takes to pump up the accumulator.
Find out what time it takes for self cycle.
Post back up.
