All,
Still working to diagnose some no-start issues with my car. After more diagnosis, we've gotten down to the fact that there may be some IAC issues, but more importantly, it appears that the WB02 is heading south.
Here's a note from my mechanic showing our latest logs.
I grabbed a data log this morning. The IAC motor & O2 sensor are looking like problems.
Today, the taget IAC was relatively high at start (90), car starts, idles for a little bit, then the IAC counts stabilize (60's to 80's) then they go
nuts and the car stalls.
Right before it stalls, the IAC count is at 180 (stuck IAC motor ??? or software glitch ?? not sure)
We also have an O2 sensor sitting at 3 volts the entire time, so in this test, if it's a heated O2 sensor, it's not sweeping.
Well, at least as far as this software is seeing it.
It's at 5 volts on start-up, then it flat-lines at 2.80 to 3.02 volts. Nothing is showing up in the Actual or Target A/F ratio's either......when the motor
dies, it goes back to 5 volts.
rpm iac
0 90
200 57
850 57
1100 57
450 57
650 50
700 35
1000 44
900 73 (IAC correction coming on-line)
700 91
1000 84
900 88
750 100
900 101
950 108
950 110
1000 111
850 112
950 118
900 132
1000 133
1000 125
1050 128
950 137 (IAC CORECTED)
1000 125-180 With no IAC Correction
800 180
450 180
500 180
550 180
500 174
350 180
800 159
Does anyone know the proper operation of the O2 sensor voltage wise? Does the above seem to indicate that this WB02 needs to be replaced?
Thanks for any tips.
Rony
rpm iac
0 90
200 57
850 57
1100 57
450 57
650 50
700 35
1000 44
700 91
1000 84
900 88
750 100
900 101
950 108
950 110
1000 111
850 112
950 118
900 132
1000 133
1000 125
1050 128
800 180
450 180
500 180
550 180
500 174
350 180
800 159
Rony
