Gene Van Horn
- Feb 20, 2013
Yea its a total waste of f. Ing money. Gotta love it
SignUp Now!I would guess 20k, minimum, port the heads, you'll have 3-4k in them to do it right to go fast. Spend at least 2-3k on the turbo, and 1k on the converter. Add tax, and shipping, so that adds up. 850 for machining and putting it together seems low, double that and round to 2k. Skip the powerlogger route, just get XFI. Also think about a complete new wiring harness to get good grounds and everything tip top, these cars are old.
I agree. Port & flow those heads (~ 45 cfm), Hemco plenum, XFI with some time in the tune, external gate & dump to the floor .You will rock the house.I would guess 20k, minimum, port the heads, you'll have 3-4k in them to do it right to go fast. Spend at least 2-3k on the turbo, and 1k on the converter. Add tax, and shipping, so that adds up. 850 for machining and putting it together seems low, double that and round to 2k. Skip the powerlogger route, just get XFI. Also think about a complete new wiring harness to get good grounds and everything tip top, these cars are old.
That is pretty much exactly the build I am going through right now and similar cost. Bottom end will handle 9's but shooting for mid 10s. Will be built to last many years and passes at that time. Made it 29 years on the factory head seal running mid 11sI don't plan on running into the 9's, I'm shooting for mid 10s. I'll have about $10 in my motor, maybe a little less. Add trans and converter that is another $4k. On my to do list after I get the car put together, engine and trans, is driveshaft and rear end. When all is said and done, including the price of the car, I will have spend $33k to make it mid to low 10s car. I see mid 10s cars for sale around $15 to $18k.
TR6 is a big fat waste of money. Guys are running 8's on stock ignitions. There are many benefits of going with an XFI setup, but it's not cheap. The main thing is being able to apply what you already have to the ground. A lot of guys won't say what exactly needs to be done to achieve these goals because they compete or are in the business of selling parts. Assuming you have the block, oil pan, front cover, cam, stock crank, rods, intake and fuel system, it would run you about $15k to build an engine capable of running 9's. How many times it would run 9's, I can not say. Cheap, fast, reliable. You can only pick 2 of the 3.I'm holding off on the TR6 based on a recommendation, but a new driveshaft is certainly on my to do list.
I would have to disagree with the first statement. I do agree it is not needed to run 9s 8s but it is prob one of the best ignition upgraded for are cars . It will help you be more consistent in runing your number though with out having to buy a xfi it does have a built in 2 step and it does provide the plugs with higher spark energy which will make your ignition system run smoother . I've yet to hit 9s but my build is still underway . I've saved a lot of cash by doing all my own work and have had very good luck on the second hand parts market but I still have a easy 25k in it including the price of the car . Just my opinion nothing moreTR6 is a big fat waste of money. Guys are running 8's on stock ignitions. There are many benefits of going with an XFI setup, but it's not cheap. The main thing is being able to apply what you already have to the ground. A lot of guys won't say what exactly needs to be done to achieve these goals because they compete or are in the business of selling parts. Assuming you have the block, oil pan, front cover, cam, stock crank, rods, intake and fuel system, it would run you about $15k to build an engine capable of running 9's. How many times it would run 9's, I can not say. Cheap, fast, reliable. You can only pick 2 of the 3.
You'll benefit more from the XFI seeing as it also has a 2 step system built in, there is auto correction, traction control, the ability to monitor and log data such as alky pressure, fuel pressure, oil pressure, boost, mph, coolant temp and a whole lot of other things that can allow you to fine tune your car far beyond what you can do with a stock computer setup. There are also other types of coil setups that are much cheaper and provide an improvement over the stock ignition coil. tr6 vs stock on a car that you're only trying to run 9's with is like 3" down pipe vs the 3.5" when you're only running 10's... It's a big fat waste of money and you will see no note worthy gains. Trying to go faster, sure, but for the goals of 9's it's not necessary.I would have to disagree with the first statement. I do agree it is not needed to run 9s 8s but it is prob one of the best ignition upgraded for are cars . It will help you be more consistent in runing your number though with out having to buy a xfi it does have a built in 2 step and it does provide the plugs with higher spark energy which will make your ignition system run smoother . I've yet to hit 9s but my build is still underway . I've saved a lot of cash by doing all my own work and have had very good luck on the second hand parts market but I still have a easy 25k in it including the price of the car . Just my opinion nothing more
this is the reality that many don't understand or respect.There are many different ways to run 9's,
Okay I log fuel pressure and can log oil pressure and what ever I would want to log . I have the ability to fine tune my car with full acess to the VE table, Spark table , A/F table and guess what it is all with my modified stock ECM . I even run flex fuel with a ethonal sensor wired in to let my stock ECM know what the ethonal content is . It was modified to run low impedance injectors . Besides that the power logger piggy backs on it allowing me to do the above mentioned thinGs so again you do not need a xfi even though I do agree they are a nice piece . But you can't say that the stock ECM doesn't have the ability to do fine tuning .You'll benefit more from the XFI seeing as it also has a 2 step system built in, there is auto correction, traction control, the ability to monitor and log data such as alky pressure, fuel pressure, oil pressure, boost, mph, coolant temp and a whole lot of other things that can allow you to fine tune your car far beyond what you can do with a stock computer setup. There are also other types of coil setups that are much cheaper and provide an improvement over the stock ignition coil. tr6 vs stock on a car that you're only trying to run 9's with is like 3" down pipe vs the 3.5" when you're only running 10's... It's a big fat waste of money and you will see no note worthy gains. Trying to go faster, sure, but for the goals of 9's it's not necessary.
"I think there was some confusion. I wasn't asking what it takes to run 9s, I was showing people one approach to take."
In that case, you could go with a stage II setup for probably less money and just dumb it down to make it more street friendly. Or you could stick with iron heads, dump a ton of money into them and run high 8's. Do you know how fast the stock bottom end has gone? There are many different ways to run 9's, it's just a matter of time, money and what will help you sleep and wake up with a smile. For some, it's doing more with less. For others, it's hunting rabbit with an cannon (overkill) lol. Then there are the people that just want something quick, reliable and consistent. At the end of the day, it's all for good fun!
I never said you couldn't and I also never said you needed to go with xfi. I think it's wonderful that you can do so much with stock stuff. However, you're talking about a computer from the 80's vs a computer from today. Like tr6 vs stock. You don't need it, but it's nice to have lol.Okay I log fuel pressure and can log oil pressure and what ever I would want to log . I have the ability to fine tune my car with full acess to the VE table, Spark table , A/F table and guess what it is all with my modified stock ECM . I even run flex fuel with a ethonal sensor wired in to let my stock ECM know what the ethonal content is . It was modified to run low impedance injectors . Besides that the power logger piggy backs on it allowing me to do the above mentioned thinGs so again you do not need a xfi even though I do agree they are a nice piece . But you can't say that the stock ECM doesn't have the ability to do fine tuning .
