Is This A D5 ?
olds403
I got this torque convertor with a BRF tranny and I can not confirm it is D5 or not. The convertor is stamped with a "5" along the outside case. The yellow sticker says 8653420 CBCF. Before I go through all the trouble of installing this tranny...just want to be sure..........
thanks..............
Yes, that is a "D5" converter. The code breaks down as C: 200/200-4R/early 700 B: 1996 stall C: 330 ft/lb 28 degrees travel F: 3 lugs, 245mm style lug
Some were actually stamped with the D5 and some were just 5 along the outer diameter. I have 3 that are just 5 and one is still in the original car.
