I'm about to buy a lot of parts here very soon and need to know if this set-up is good, not good enough, don't need or just don't match up right. First my goals are low 7's in the 1/8th or 11.3-11.5 in the 1/4. I will be running E85 and 25# of boost (maybe more or less not sure what is a good number yet).
THINGS NEEDED:
Port stock heads
Port stock intake
206/210 .516 roller cam kit with beehive springs
1.5 roller rockers or HD rocker shafts with rocker shaft supports (don't know yet need help)
ARP head studs
80# injectors
DW 300 fuel pump
Front mout intercooler or Stock location (don't know yet need help)
PTC 2800 L/U converter
High performance coil
HP wastegate actuator
275-45-16 drag radials
THINGS ALREADY HAVE:
Stock block with 1800 miles
Hot wire kit
3" down pipe
TA49 turbo
Rebuilt 2004R stage one
Stock gears
Have some body bracings
I'm not for sure what rockers to go with, would like rollers just don't know if I need to have head work to use them. What roller rockers should I use without doing machine work to the heads or what machine work needs to be done to use them? Is the HD rocker shaft good with the lift I have?
Also with the intercooler do I go with fm or sl?
With this cam what machine work needs to be done to it? Will the retainers hit or is the lift not big enough?
Do I even need to port heads and intake?
The other things I'm going with is a powerlogger, 3 bar map and a wide band inline.
I may be missing some things, but I think this is what I need. I really need everyones input on this, I just don't want to buy these and either don't need or its wrong for my goals.
Thanks, Otes
THINGS NEEDED:
Port stock heads
Port stock intake
ARP head studs
80# injectors
DW 300 fuel pump
Hot wire kit
3" down pipe
TA49 turbo
Stock gears
Thanks, Otes
