- Apr 4, 2002
Just got Razor's alky kit all hooked up. I havn't got my alky chip yet, but figured I'd go play around with some distilled water and 91 oct. (just to knock the carbon off the tops off the pistons of course
). First two base line pulls with NO alky was at a stedy 14 lbs. boost +- 1/2 a lbs. with about 1.5 * of KR at about 80 MPH. Then the only change I did was turn the alky (H2O) on. Did the same pull two more times. Both of these pulls the boost stayed at 12 lbs. for about four seconds then stedely creeped up to 20 lbs when I lifted. (no KR). I then removed my RJC boost controler and adjusted my stock waist gate for 14 lbs. I did the same with and with out H2O pulls as above with the same consistant results. So, why is my boost stedy with out H2O and goes from too low to too high with H2O?
