Those are NGK UR5's and if you notice the ground electrode is burned off,but the center electrode is unburned, and the ceramic is gone all the way up, the piston is not melted either. No big pops, smooth as silk.
SignUp Now!norbs said:Those are NGK UR5's.
Cheeseburger said:Time for a R.T. rebuild, lol.![]()
norbs said:"silent detontation" possible?
norbs said:The car was run with Razor's alky kit and 94 octane fuel @28 psi boost. The ecm is a gen 7 and I don't think it has issues as the duty cycle is under 50%. Timing is at 23 and the piston or head gasket is not metled. Only thing that i can think of is uneven distribution in the plenum or the alky, but if that was the case, all the buicks with the alky kits would be having similar problems!
norbs said:People have run more boost and more timing with alky, ask Razor
