SignUp Now!Start up 14.1 warmed up driving 13.1-13.3
What's the issue with it?
Did you replace the O2 sensor? Reason I ask is because I have had a sputter when accelerating and hooked up my directscan....found O2 mv going to -0- at times, even when TPS was increasing. Looks like its time for a new O2 sensor. Last time i had a sputter it was the TPS sensor, so I actually suspected that first.
Run a Caspers coil pak tester on the ign box. Do it cold, run til heated up, do it again... see what you get.
I went through a similar sounding situation, the car would only do it when it got hot and I tried everything to fix it. It ended up that it was the cam sensor cap. When it got heat soaked it would start to act up. I ended up just switching to a caspers cap(very nice piece) and all was better.
You really need a scan tool. Someone had Directscan with a laptop for $200 in the parts for sale thread.
I have a scanmaster.
That's not good enough when you are troubleshooting intermittent problems. You need Direct Scan or Powerlogger to get real time data.
