I'm in need of some help with the boost control feature of the ISAC. I have a TurboSmart wastegate and BWR 3.5 downpipe with a dual solenoid setup. The spring in the gate is 7lbs, which is about all the boost I'm making right now. Under the config tab, I have solenoid 1 set at increase and solenoid two set as decrease (not bleeder/blocker) and I've verified the wiring. Also under the config tab, I've checked the boost control enable box and selected boost%/RPM. My enable parameters are working because I watched solenoid 1 go up to a 50% duty cycle yesterday but nothing seems to be happening.
1. Any recommendations based on the attached diagram of my hoses?
2. Should I ditch the two solenoid setup? Any recommendations on how the hoses should be routed in that scenario?
If anyone has a similar setup and has a diagram of the hoses and their config setup I would be really appreciative. If I don't get any leads I'll be headed down the 'ol trial and error route.
John
John
