- May 27, 2001
We received our first production run of ISAC methanol controllers yesterday. Price on the units is $359.00 plus freight. This is an introductory price until we sell out half of the first run (30 units or so) and then the price will go to $389.00.
Unit ships with the ISAC controller, 3 wiring harnesses (There are 3 individual harnesses for installing the unit), a USB cable and a CD with the manual and tuning software on it.
Full kits are available for anyone that would like a turnkey package. We have decided to use Labonte Motorsports for our kit supplier. Talking with Dan @ LMS, they are customizing a kit for our needs to work with the ISAC. The kit will ship with pump, nozzles, line, a one gallon tank, a low level sensor, a flow control solenoid and the misc hardware to install the kit. We have been running LMS kits on several of our cars and they've been worry free. We run straight methanol in them with a lubricant. We have been mounting the tanks and pumps in the trunk and putting the flow solenoid under the hood. It makes for a very clean installation and keeps your methanol away from any potential flammable situations. The full kit sells for $679.00.
Also of interest, Labonte also sells a flow control device which can be used by the ISAC as a failsafe. Measuring flow is an excellent method of monitoring the health of the system. If the pump becomes weak or a line gets clogged up, flow will drop and the system will drop your boost out to prevent engine damage. The ISAC already has several built in fail safes including air/fuel ratio leanout (When running a wideband), overboost (When running the boost controller), low level and the above mentioned low flow.
Anyone interested in placing an order can call me at the shop. We will have a cart on the website in the next week or so. Below are a couple of pictures of the kit and unit.
