SignUp Now!9.53 - 9.377 = .153 in the hole.
A.j.
Have these new pistons forged 3.860 bore dish-.250 comp.ht.1.717
what combo stroke&rod will work? Going in stage 1 3.8 maybe? Is dish alot looks to be? Thanks in advance for any help.
Thanks doc
My Math wrong?
point me right boss...?
A.j.
Great post. You typically wouldnt build it around any particular part(s) unless you are class racing.Typically you wouldn't build an engine around a set of pistons. You should figure out what bore,stroke, rod length and deck height will be and order a set of apropriate size pistons which will give you the compression ratio you want.
Neal
.153 in the hole is f-. not your math
