SignUp Now!I just installed it this past weekend. But I was also doing intercooler repair and replacing the A/C compressor with a delete pulley. With all that out we still took off the accessory bracket to move the power steering at which point the steering shaft was a breeze. We didn't look at removing from underneath. One thing to watch for, when done we saw one of the power steering hoses rubbing against the new u-joint (guess that's what the rubber boot on the old shaft is for), we tied the hose out of the way.I tried searching, how do you install this thing? The top looks easy, but the bottom is buried. Do you access that from underneath? I dont even see how to fit it in there unless you yanked the steering wheel, and pushed it through.
I wouldn't even bother with this. Only upgrade it provides is more room for changing spark plugs and the occasional cracked header
Reviving an old thread, I can't figure out how to install this thing. There is no way to get at it with the a/c and power steering in the way. No access at all. Anyone install the the lower half from underneath the car, and then attaching the upper half from the top?
I finally was able to remove the lower bolt. I moved the power steering reservoir out of the way. The top bolt is another story. It won't budge, started to strip, so I am dremeling off. I have half the bolt gone, but it still won't go. I'll try again tomorrow.
Finally got the old one out. Dremeled the nut, and the bolt fell out. Couple whacks with a hammer and the shaft compressed. I can't get the new one on either end. Should I torch the ends to try and open them up? If I could get them started, I would hammer them on, but I can't get them to budge.
