I just got the motor back in the Ttype a few weeks back. Did a little freshening and I finally have 300+ miles on it and have started tuning it back in. I put the Testa chip back in it (took out the junk ass thrasher) and I noticed that the BLMs and INT are pegged at 150 at idle. Please correct me if Im wrong, but that means the car is lean right? Well, according to my fuel pressure gauge, my fuel is 45-47 line off which I believe is a tad high for blue tops. Ive had it up to 50psi line off and there is no change in the BLMs and INT at idle. Idle quality is pretty darn good and there is no tip in stumble at all. WOT the BLMs and INT lock at 128, and the car runs out pretty well. Cruising speeds the BLMs and INT are "within range" at 120-140ish. Its just idle its pegged. Can anyone give me some ideas? Thanks!!!!!
