Originally posted by SideSlip
I think my engine is toast. At idle it's quiet, but rev it slightly and it makes a loud metallic clacking sound deep inside the block. What could it be? Do I need to tear the whole engine down to fix it?
Originally posted by ChrisCairns
There is a possibility that it's just the torque converter to flexplate bolts. The sound you described is exactly what mine sounded like when they came loose......
Remove the dust cover from the flexplate and take a wrench, in other words don't just try to wiggle them by hand, and see if you can tighten them. And keep your fingers crossed.
Ya........It's a rod bearing. The engine is original and only has 30,000 miles total and has never seen more than 15lbs. boost. I thought these Buick V-6 short blocks were tough.......what gives???? My stock 5.0 short block could take more abuse.
Anyway Turbo Regals rule......and I want to prove it to my Stang buddys, so what should I do for a re-build??? I want something that will stand mid 11's easily. Suggestions????
The rear rod bearing on the passenger side was burnt to a crisp. The pan was full of bearing metal, but the crank was in pretty good shape, I might even get away with a polish, but that's wishful thinking.
How do I prevent this from happenning again?
