I wiped a lobe and finally got my engine completely back together tonight, but I couldn't get it started. I have a couple questions...would just cranking it with the spark plugs off build up enough oil pressure to get the oil to the heads? And is there a way to get the oil to the heads without starting it?
Also, I tried to start it briefly to see if I could build up oil pressure and I wasn't getting any fuel. The pressure gauge on the fuel rail read 30 PSI, but I guess the injectors aren't firing. Any suggestions?
