- Apr 10, 2009
Nice score!!!
SignUp Now!Possible fuel pump hot wire relay check where the wires lead to just follow the wires.
X2...Don't fix what ain't broke. It will break on it's own in time!I would just leave everything alone, you can just verify your fuel pressure up front and you should be fine no need to drop the tank unless your having some sort of problem? If it aint broke don't touch it.One thing you can do since your dying to work on it, is just go thru your spring cleaning which are regular wear items,
just looking at the engine shot you can tell that car has been cared for no need to do anything. Enjoy it.
http://www.gnttype.org/maint/basics.html
It's normal should be a spring also back there to keep the grille pushed forward so if pushed in it should go in a few inches
Well, a lot depends on what your goals are. Is it a car you want to drive a couple of thousand miles a year and always be reliable (trying not to laugh) and get 20 miles a gallon, or is it a car you want to take to the track and live on the edge. My set up has been carefree for over 75k (145k total), and I get 22mpg, but I don't race it. For that matter, I use regular gas just because I know I am not going to go WOT. If want to play a little I use a tank of 93. Now, if I were to race it, I would add alchy, a little more converter, a little tranny tweaking, a line lock, slicks and bags and be well into the 11's. But, with shitty gas milage, breaking parts and a light wallet, (although I would have a good size grin).Good to know about the speakers, although I don't think it will apply in this car. I have torn the interior apart trying to learn as much as I can while it is too snowy outside to drive this thing. I have discovered all of the cables and speaker wires running through this car... I do not want to say its a messs, but suffice to say, I am cleaning up what is here. The Alpine head unit is trashed and the extra wiring to the battery was to supply the entire stereo system, which is sort of cool since it resides on a breaker of it's own on its own circuit.
As far as me not modding this car... I don't know if I can stand not doing some stuff. I know that the chip is stock which will get replaced once I figure out what I want to do with the car... First thoughts were to upgrade the valve springs since it seems they are a weak link. Injectors are 30#, which is just barely above stock. I need an FPR, the pump and hot wire kit are already done... I can't help think that a stock appearing turbo upgrade would be cool... But what else do I need to upgrade along with that? Down pipe, bigger injectors, intercooler, pulleys? Again, I dont want to go nuts, but from my research this would be a nice jump from stock.
Thoughts?
Thanks again Steve.Well, a lot depends on what your goals are. Is it a car you want to drive a couple of thousand miles a year and always be reliable (trying not to laugh) and get 20 miles a gallon, or is it a car you want to take to the track and live on the edge. My set up has been carefree for over 75k (145k total), and I get 22mpg, but I don't race it. For that matter, I use regular gas just because I know I am not going to go WOT. If want to play a little I use a tank of 93. Now, if I were to race it, I would add alchy, a little more converter, a little tranny tweaking, a line lock, slicks and bags and be well into the 11's. But, with shitty gas milage, breaking parts and a light wallet, (although I would have a good size grin).
A couple of other tips come to mind. When you are driving and you hit a bump, especially in the cold, you may hear a noise that sounds like it is coming from your dashboard or the base of your windshield. To fix this noise you simply pull your oil dipstick, wipe your finger on the oil, and clean your finger off by wiping it on the round rubber bumper under the back of the hood between the 2 wipers.
