just installed scanmaster 2.1
viokrome
I just installed a scanmaster 2.1 on my car and here are the numbers, where to go from here?
key on eng. off-------------- eng.@ idle
------------------------------234 to 664 00
af 03-------------------------05
lb 00-------------------------39
bat 12.1----------------------13.8
int 128-----------------------131
bl 128------------------------145
mph 00----------------------00
clt 182------------------------178
ats 103-----------------------84
r 000-------------------------750
tps .44------------------------.44
iac 150------------------------25
cc 00--------------------------22-37and counting up
nal 00-------------------------00
r 000-------------------------000
wee bit high blm(lean)
dont understand how your rpm is 000 at idle??
Stock MAF ,Stock chip, car all stock except for a K&N filter in original airbox. Sorry @idle rpm 750 could not get the TPS to set above 4.44
for WOT so I have a new one on order. I am thinking Need a new O2 sensor to? I cleaned the throttle body and IAC needle and seat. 43888 original miles.
no problem..my TPS would only do 4.43 at WOT still have same tps...doesnt seem to be a cable problem..maybe i need to order me one as i am .42 at idle...are your cc rapid?? any preturbo leaks?drop your .44 to .42 you just may get that 4.46 WOT..
Ok, got my tps. set right .42-4.50 it was the t.v. dentent cable out of adjustment. Still feel like I am chasing my tail, car dies on cold start up then when warm still has high blm's 145, checked cleaned iac, new tps,spark plug change, 02 sen looks ok. I guess keep looking for vac leak and change 02 and iac next? any ideas.
not trying to jack ur thread..here are my new numbers after new o2,manifolds,MAF,EXSHAUST,everthing all sealed up...idling have 160 Tstat on the way...need to play with tps some more
Blackbeauty our numbers are pretty close, I wish I could get my blm number down more. I am going to check my fuel pressure and change the fuel filter and o2 sensor to a denso and see if that works. I checked the whole engine for vac leaks and found none.
