No disintegrations
- Dec 27, 2015
Voltage drop test. Set meter to DC volts. Put one lead at beginning of wire your checking and the other towards or at the end of that same wire. With the circuit working or functioning or under power the meter should read very close to zero. If you get half a volt or higher or similar that's a problem. Edit ( Over .2 or .3 is getting iffy)
