SignUp Now!Opened up the bolt holes a fuzz. Have also had to bevel the flexplates before as mentione above. These problems were on early overseas crankshafts.Kip what did you do to correct the issue?
I'll double check that. I just held it up to the crank with the sfi sticker facing out.I have a JW flywheel on a RPM stroker crank. No problems with installing it. All the holes lined up. Be sure it is on with the correct side facing front.
We’ve all done something like thatYeah so I was a dumb ass. I was holding it up to the crank backwards. Flipped it around and it fit perfectly. Thanks for the help.
