Mike T
- May 3, 2013
Are you guy's checking the actual stretch of the bolt?
Here's what I've found. According to a chart that K1 put out the ARP 2000 7/16 1.600 under head length bolt requires .006-.0064 stretch to do it's job as intended. A search on this board is showing various torque numbers for this bolt/rod combo and they are all far below what it actually took to get .0062 stretch on mine with ARP moly lube.
The stretch gauge is very cumbersome to use so I use the torque plus degree method carefully measuring each bolt before and after with a micrometer. It took between 90 and 100 lbs. Had three high quality torque wrenches on hand and they read the same so calibration is out.
