TR Custom Parts
Mark Hueffman - Owner
- May 25, 2001
See a lot of Mustang guys using these. Not much mention of Buick guys running them though. Currently running a Walbro 340 with Racetronix hot wire kit and not getting the "recommended" fuel pressure increase of 1 lb of fp for 1 lb of boost. Mentioned what was happening in a previous post and just want to know if this is a worthwhile mod. Have replaced fp regulator, checked for any vacuum leaks, etc etc and seem to be getting 5 lbs less pressure than I should be getting. Fuel restriction removed in hanger, new filter. Pump and tank new as well.
Couple of screenshots of a recent run I did here on the street. No traction spinning the tires up to around 60mph and then ran out of road around 100mph. Was just testing my PTC 9.5 non lockup TC to see what kind of boost I could get off the footbrake. Let it go at 11 lbs knowing it would never hook on the street especially without any burnout. Notice the BLM spike I got at the beginning of the run. This shows up whenever I get on it.
