Knock sensor help!
lethal231ci
The Next Generation
Knock sensor starts goin off around 8psi of boost, but not throwing any codes...whats goin on!?!
Don't feel bad... mine was showing 15 degrees of knock... :eek:
It looked like the DP was hitting the seam where the floorpan and firewall are joined together so I cut the seam away with a sawzall.
Just waiting for decent weather to test drive again. :D
Subscribed.
My Caspers gauge shoots into the red under 5PSI. Also, my powerlogger shows no signs of any real knock. I checked the DP and it's fine.
Also, I know it's not the guage because I swapped it out in my brother's GN and it didn't show any knock at all.
I'm sure my motor is fine then.
Yullose keep me posted if that works or not!
Thanks guys!
