Laptop need for FAST XFI...
1985GN
Breaking parts
looking for a cheap laptop that i only need to run FAST XFI on and nothing else...let me know what you guys have
Laptops
Thanks for the bump Tim!
What are the minimum specs for FAST XFI?
I have several laptops ready to go.
Just let me know what your trying to spend.
Thanks,
Jason
AffordableGN
thats a good question i will have to look into it and see what it needs to run it on a laptop
Fast Xfi Specs
I Found The System Requirements For Fast Xfi:
This Is Right From Fast's Website:
Pc: 80386 Or Higher Cpu
Operating System: Microsoft Windows 95/98/nt/me/2000/xp.
Graphics: Vga Ram 2mb Minimum
Hard Disk: 1 Mb Minimum
Rs-232: A Free Com Port (#1,2,3 Or 4 Without Conflicting Interupts) Is Required. If Your Pc Does Not Have A Serial Port Connection You Must Use A Usb To Serial Port Adapter Available From Fast As Part #30-7044.
This Means In Layman's Terms:
The Pc Does Not Have To Be A Top Of The Line Laptop.
It Does Require A Serial(com Port)
Or You Can Buy A Usb To Serial Adapter From Fast.
I Am Sure I Have A Laptop That Would Work.
Do You Have An Inverter For The Car.
This Is Used To Convert Your Cigarette Lighter Plug To Ac.
They Are Around $20-$60 At Any Parts Store.
Most Older Laptop Batteries Don't Hold A Good Charge.
It All Depends On Your Price Range You Want To Spend.
It Also Depends If You Would Use It For Anything Else.
I Have One Slow Laptop For My Car.
And A Faster Laptop For Home And Business Use.
Let Me Know What You Are Looking For And Your Price Range.
Thanks,
Jason
Affordablegn
