GNSCOTT, air doesn't expand in the intercooler, it contracts. Air going into the compressor might be 650 acfm, coming out and going into the IC it might be 380 acfm, and coming out of the IC and going into the intake it might be 310 acfm. The magic of compression and cooling! Raise the boost and the compressor inlet and outlet volume flows might go up, but the IC outlet will still be the same, because that is the volume of air that a 231 can ingest. That's why bigger throttle bodies don't do a whole lot for us.
Similar vein, if you think you need bigger pipes, increasing the size of the compressor inlet pipe will give you the most gain, then the size of the IC inlet piping is next, and you'll get the least out of going bigger on the IC outlet piping.
But let's not forget our '84/'85 brothers, a hot air car with the throttle body on the compressor inlet will probably see some real nice gains with a bigger throttle body. Their throttle bodies do see a big volume flow jump when running more boost.
John
