I can hold 12 lbs plus with vac brakes...no e-brake.
Try this..
1.After the burnout pull into the first light slowly. Get as far into the pre-stage as you can without tripping the 2nd bulb then comepletely stop the car.
2.Put it in neutral...Put your foot sideways om the brake pedal so you are putting pressure with your knee and not just your ankle muscles, try to have your foot flat on the pedal. And try to push it thru the floorboard as you rev the engine. You can actually feel the pedal going in as you rev the engine. Rev it up and let it settle down...repeat...repeat....repeat. 4-5 times.
3. DONT take the pressure off of the brake!
4. Put it in gear.
5. Start boosting. When the car starts to move...light the 2nd bulb as it creeps...This is the tricky part... When the car moves ,let off of the gas slowly. The deal is this..the "trick" is...
Getting good at "controlling" the roll from pre-stage to stage, without letting off of the throttle TOO much and loosing boost....OR...Not letting off of the throttle enough and deep staging or red lighting.
I use the throttle to control my roll into the stage lights instead of bumping the brakes. After building all that brake pressure to get the boost way up there, if you bump the brakes you will lose all that holding force.
Or ya could install a t-brake:biggrin:
